2 members (qside, 78buckshot), 76 guests, and 1 robot.
Topics128,072
Posts1,055,907
Members48,429
#58684 04/01/2006 6:07 PM
Junior Member
Junior Member
WE just removed the Small block from the 63 pickup. When we pulled the heads off i noticed it has a 4 inch bore, so im guessing it is a 350. It is an original engine and hasn't been rebuilt. I have a 350 bored .040 over, with a 280 comp cam, and 305 heads. It leaks oil due to a groove in the crankshaft. Should i put this motor in, or rebuild the 350 that has never been rebuilt? ALso, how can i tell what year engine it is. THanks
#58685 04/01/2006 9:12 PM
Riding in the Passing Lane
Go to www.nastyz28.com & get the numbers off the engines. I can,t imagine a 350 with cam & 305 heads. You can put a sleeve on that crank if it,s a 86 up with 1 piece rear main seal.
1972 Chevy c10 Cheyenne Super
#58686 04/02/2006 12:32 AM
Quote
Genuine redneck engineering... Just increase the compression without considering the flow capability of the head.
#58687 04/02/2006 4:20 AM
It cannot be a 350 engine as original in a 63 pickup. 350's weren't built until around 68' or so. It may be a 327 however or even a 283 with 4" bore. Lots of them were built up as 301's, 4" bore x 3" stroke = big rpm's.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
#58688 04/02/2006 4:36 AM
Junior Member
Junior Member
Well, i never meant to say it was orignal if i did. I know it's not. It was an orignal I6 truck. I believe it's a 350, however, the bellhousing is different then a brand new 350 crate engine i have. it is missing a bolt hole at the very top of the engine where the bell housing connects. lol, my 350 with the cam and heads runs VERY good. IT'll spin the 10 inch wide tires off of my 62 impala. lol
