| | | Forums66 Topics128,049 Posts1,055,546 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#58684 04/01/2006 6:07 PM | Joined: Feb 2006 Posts: 19 Junior Member | | Junior Member Joined: Feb 2006 Posts: 19 | WE just removed the Small block from the 63 pickup. When we pulled the heads off i noticed it has a 4 inch bore, so im guessing it is a 350. It is an original engine and hasn't been rebuilt. I have a 350 bored .040 over, with a 280 comp cam, and 305 heads. It leaks oil due to a groove in the crankshaft. Should i put this motor in, or rebuild the 350 that has never been rebuilt? ALso, how can i tell what year engine it is. THanks | | |
#58685 04/01/2006 9:12 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Go to www.nastyz28.com & get the numbers off the engines. I can,t imagine a 350 with cam & 305 heads. You can put a sleeve on that crank if it,s a 86 up with 1 piece rear main seal. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#58686 04/02/2006 12:32 AM | Joined: Oct 2003 Posts: 363 Member | | Member Joined: Oct 2003 Posts: 363 | Originally posted by Wrenchbender Ret.: I can,t imagine a 350 with cam & 305 heads. Genuine redneck engineering... Just increase the compression without considering the flow capability of the head. | | |
#58687 04/02/2006 4:20 AM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | It cannot be a 350 engine as original in a 63 pickup. 350's weren't built until around 68' or so. It may be a 327 however or even a 283 with 4" bore. Lots of them were built up as 301's, 4" bore x 3" stroke = big rpm's. | | |
#58688 04/02/2006 4:36 AM | Joined: Feb 2006 Posts: 19 Junior Member | | Junior Member Joined: Feb 2006 Posts: 19 | Well, i never meant to say it was orignal if i did. I know it's not. It was an orignal I6 truck. I believe it's a 350, however, the bellhousing is different then a brand new 350 crate engine i have. it is missing a bolt hole at the very top of the engine where the bell housing connects. lol, my 350 with the cam and heads runs VERY good. IT'll spin the 10 inch wide tires off of my 62 impala. lol | | |
