| | | Forums66 Topics128,162 Posts1,056,943 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 45 New Guy | | New Guy Joined: Sep 2009 Posts: 45 | Has anyone had the problem of re-doing the throttle linkage, and gas pedal pushrod after installing Fenton cast iron exhaust headers? the Fentons block re-installing the stock linkage. I've got a 235 in a AD '55 1st Series 1/2 ton pickup. My understanding is that you move the engine block mounted pivot arm towards the rear of the block where there is another attachment hole, and mount the new linkage arm at this point. Then you measure and cut the gas pedal pushrod to match the shortened distance. Does this sound correct? Any tips appreciated! I'm running the stock intake manifold with the stock single Rochester carb.
| | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | I'm not a big fan of irreversible mods to dificult to find parts. I just bought a length of 1/4 rod and a rod end and bent up a new pushrod from the bell crank to the carb, going around the headers. when I sold the truck, I reinstalled the stock exhaust and linkage.
regards, Leon | | | | | Joined: Sep 2009 Posts: 45 New Guy | | New Guy Joined: Sep 2009 Posts: 45 | Thanks, that's a great tip. I am reluctant to cut up the stock pushrod; I'll take your advice. | | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | Consider Mr. Gasket 3811G ball joints for the connection to the carb. They can be disconnected easily. regards, Leon | | |
