4 members (wilbur53, burgundybolt, Jack Ryan, 1 invisible), 86 guests, and 3 robots.
Topics128,086
Posts1,056,331
Members48,442
#58504 03/30/2006 3:47 AM
I pulled the motor out on one of my trucks and took it apart. I haven't decided if I should rebuild it or find a diffirent one that in a little better shape. My problem is what technics are there to keep the engine parts from rusting while in storage? The block is in good shape would hate to see it get wrecked from humidity.
38 original
48 panel
59 stepside
46 in the back forty
It may sound strange but it's true. You can vacuum pack it in a heavy plastic bag. Summit may have the bags.
local parts store should have a spray oil that is for storing engine parts then put in plastic bag from summit (good bags I have a few)
Cover everything heavily with wheel bearing grease and wrap it up in plastic,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
American Metal Cleaning in Portland, who just cleaned my block, head, and crank coats them in wd40 and further recommends coating it with tranny fluid for storage if it will be a while till the next process. And of course, the plastic thing.
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
Keeping it coated with oil and dry and relatively dust free is the best way. You don't necessarily have to vacuum bag it. You can just cover it with a tarp and fog it with oil once in a while if you want. That's what I do with my extra 235, I have it on a stand with the head off and covered with a tarp. About once a season is enough in my garage.
Paint & Body Shop moderator
