9 members (crenwelge, 51sub, MickeyP, Otto Skorzeny, Thom75, TUTS 59, tclederman, JayDP, 1 invisible),
166
Mod | | | Forums66 Topics128,284 Posts1,058,531 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 26 Apprentice | | Apprentice Joined: May 2009 Posts: 26 | I have a 52 half ton that I am rebuilding. I am swapping the 216 for a 235 out of a 57. While its apart I'd like to swap out the 3 spd column shift for a 4 spd on the floor. I want to keep the stock torque tube driveline. What year(s) tranny will bolt up? Thanks | | | | | Joined: Feb 2006 Posts: 150 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 150 | I think your only choice is a sm420 up to 1954. Good luck, you shouldn't have any problem locating one of them. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Any SM420 should bolt up, as long as you have the torque-tube rear cover for the transmission. You'll also need a 4-speed torque-tube u-joint (and speedometer drive-gear and driven gear).
Tim | | | | | Joined: Aug 2006 Posts: 21 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 21 | Patrick Dykes makes a conversion kit for about $500 that lets you put a modern saginaw trans into the orig driveline and keep the torque tube.
Vendor and manufacturer of the No name, No fin, No logo cast aluminum 216/235/261 Valve cover and Hold Down Knobs
