3 members (RLB, Oswald, GRNHydra), 86 guests, and 2 robots.
Topics128,030
Posts1,055,430
Members48,422
#58448 03/29/2006 1:23 AM
Junior Member
Junior Member
Did all of the 235's make use of the three rings placed between the head and the intake manifold?
I thought I read somewhere that they were dropped at some point. Both the head and intake manifold on my 1960 vintage block appear to have been machined to accept the rings. (Which I don't have).
Mike
#58449 03/29/2006 2:35 AM
Mike, They ALL used the rings. Using the rings makes a better job, won't move around and less likely to leak. You can buy these from most truck vendors or make some from exhaust tubing. Also I like to use the Copper Coat gasket sealer for the manifolds.
1946 1/2-Ton Chevy
