| | | Forums66 Topics128,157 Posts1,056,874 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2009 Posts: 48 | Got most of my dash wiring replaced with a harness salvaged from a scrap yard.
Gauges appear to work, I have headlamps (Yay!), but still need to wire tail and signal lamps.
There is a small harness of just a few wires I need to figure out. It has two dash lamps which I think are turn indicators, a two wire flasher relay, and a flat six pin connector. Going the other direction it is fairly long, terminating in a two pin and a three pin connectors.
There is a Signal Stat turn switch on the column, with seven wires. The seven wire colors do not match the six pin Chevy connector.
Anyone have a diagram to help me out?
If I can complete this wiring I can finally drive my truck! I've looked on-line for schematics, but the only one I could find was too small to be legible. 1957 Chevy 3600At these prices I want my gas 100 octane, leaded, and my windshield washed! | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Check out this tech tip. It has the colors for a Signal-stat 900 and instructions to figure out the wires on others. | | |
