4 members (Jim K, tclederman, Lightholder's Dad, Biermann), 113 guests, and 0 robots.
Topics128,163
Posts1,056,918
Members48,458
Got most of my dash wiring replaced with a harness salvaged from a scrap yard.
Gauges appear to work, I have headlamps (Yay!), but still need to wire tail and signal lamps.
There is a small harness of just a few wires I need to figure out.
It has two dash lamps which I think are turn indicators, a two wire flasher relay, and a flat six pin connector.
Going the other direction it is fairly long, terminating in a two pin and a three pin connectors.
There is a Signal Stat turn switch on the column, with seven wires.
The seven wire colors do not match the six pin Chevy connector.
Anyone have a diagram to help me out?
If I can complete this wiring I can finally drive my truck!
I've looked on-line for schematics, but the only one I could find was too small to be legible.
1957 Chevy 3600
At these prices I want my gas 100 octane, leaded, and my windshield washed!
Check out this tech tip. It has the colors for a Signal-stat 900 and instructions to figure out the wires on others.
