5 members (1955 1 Series, 49nut, rfs56trk, Eisenholtz, tclederman), 88 guests, and 0 robots.
Topics128,046
Posts1,055,618
#583817 10/16/2009 1:53 PM
I got this question on my 261 head auction on Ebay. Can anyone answer this?
Hello fttp - I have a 1954 Chevy 210 - the engine is a 265 C.U. in line six cylinder - 3 on the tree -- Is the 261 Cylinder head the same as the 265 C.I. CYLINDER HEAD ?? Bob
Chris
The guy sounds mixed up. The 265 Chevy is a V8.
Steve
'49 3800
'52 3600
'57 3100
The guy probably meant 235, not 265. As Ghostrider said, a 265 was the first smallblock Chevy V8.
Mike
1958 Chevy 3200 Fleetside
1958 GMC 100 Wideside
Did you get free advice today? To donate to this site using PayPal is fast and EZ. Click here: http://www.stovebolt.com/office/thanks.html
We are pretty sure you did mean 235 Tam Trucker so I won't let anyone beat you up for a simple typo. The heads are a little different but they will interchange. The are some additional holes in the 261 head often referred to as "steam' holes but I don't know where that came from as there is no steam involved. However it is necessary to make sure the head gasket used also has these little gems or there will circulatory trouble ahead. Kind of like a blocked artery I suppose. I have not done this procedure but am told that the holes can be drilled in the 235 gasket. I think (w/o looking) there may be some additional info available in the archives so I'd suggest a thorough search as I always do. There has been a lot of discussion about using 261 heads. But WTH, "if" your needing a new engine why not try for a complete 261?
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
The "steam" holes are needed because the 261 cylinders are "siamesed", no coolant passages between them. The holes allow coolant to flow upwards past the joined cylinder walls instead of creating "steam pockets" caused by lack of coolant flow. If you run a 235 head on a 261, they need to be there. The 261 head can fit the 235 with no problems- - - -the holes don't have to be plugged. If you choose to use a 261 head gasket for a drill guide, be aware that the holes have to be drilled at a slight angle, not square with the head surface. I think there's a good tech tip somewhere that explains the procedure in detail.
Thanks guys,
So I'll tell the guy that yes he can use the head on a 235 (assuming that he has the original type motor and not a 265 V8), but why?, when he could use a 235 head which is to find.
Chris
Walked through an old car/truck wrecking yard today that I have not been to for 20 years.
"We are pretty sure you did mean 235 Tam Trucker so I won't let anyone beat you up for a simple typo"
Nobody is beating him up, and he did mean 265 because that's what the fellow who is interested in buying his head asked him about.
Steve
'49 3800
'52 3600
'57 3100
