Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (farmallb, baldeagle, TGP, 1955 1 Series, Dennys28, cmayna), 70 guests, and 4 robots.
Topics128,004
Posts1,055,265
Members48,418
#582217 10/11/2009 12:22 AM
I am changing shocks on my truck due to a engineering problem by me, they were to long and were hitting the internal stops.
How much travel is needed on the compression side and extension side of a modern tube type shock?
Heres what I have, setting on level pavement, there is 12.25" between the mounts. Will a shock with 9.25" compression to 14.125" extension be enough?
How much more compression do you need over extension?
Joe
Joe H #582323 10/11/2009 12:47 PM
if you have a stock height truck call your local flaps and they can give you extended, collapsed, and stroke. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Joe H #582330 10/11/2009 1:15 PM
Here's what I did. Arm yourself with the following data:
1.0 Jack the truck up so the rear axle is hanging, then measure the length from the upper shock mounting bracket to the lower shock mount.
2.0 Now measure the distance from the bump stop to the frame.
Subtract the bump stop dimension from the fully extended length. Make sure that the shock you pick, when fully collapsed, is less than this dimension, that way it will never fully collapse.
Use these two measurements to pick the correct shock at your local parts store -or-
Go to the Monroe website
http://www.monroe.com/catalog/catalog_default.asp
and use their step by step process to pick a shock and then got to this page
http://www.monroe.com/catalog/miscApplications.asp
and click on the link "Mounting and Length Sheets" which lists Monroe shock lengths. Check this against your actual dimensions.
I have been all through the Monroe site and have a shock picked out. What I am not sure of is how much travel a front axle has during normal driving and how much it travels in each direction.
Most shocks have around 5" (+,-) of travel, so do you want most of that on the compression side or do you want to split it 1/2 and 1/2? 2/3 and 1/3?
Joe
Joe H #582408 10/11/2009 5:36 PM
ODSS President
ODSS President
More food for thought... Lighter and stronger.
~ Cosmo
1949 Chevy Half Ton
Cosmo #582470 10/11/2009 9:54 PM
Riding in the Passing Lane
When the axle is at the snubber there should be a small amount of travel left. The Extension is used to limit the upward travel.
1972 Chevy c10 Cheyenne Super
