2 members (Peggy M, Ponchogl),
52
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2007 Posts: 92 | Hi all. . . been a while since I've posted. I've been working at work on the truck on the HOG and my marriage (not in that order  ) Anyway - I know someone here will have an answer for me.... I have a SB 327 in my 3100 and my gauges are all new and senders as well. So I'm driving around town puttin her through her paces and I notice that the water temp just keeps climbing. . . 190 - 200 - 210 and then stops around 220. I've also changed the coolant and thermo (180). Is 220 water temp right for this engine? I've also got some tuning to do with the cold idle, choke (or something in this area). It's real choppy in the acceleration till it gets all wormed up (220). Let me know if you need any more info - but the big question here is about the water temp. Thank experts  | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | 220 is a bit warm but could be if you have a sealed system with overflow tank. Did you check the thermostat before installation? You might want to try a new radiator cap as well. An improperly tuned engine could run warmer than normal so double check your timing. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If it were mine, I would want it running close to the thermostat opening temperature. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Do you have a shroud for the fan?
Bill Burmeister | | | | | Joined: Apr 2007 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2007 Posts: 92 | Fried - thats what i was thinking - too warm. I'll look into a new cap - good sugestion.
Trucker - I've done much research on the subject and thought the same as you. But I found out that it's not what your thermo is rated for that you should be at. It just allows the coolant to start flowing at 180 (or whatever your rated at).
LongBox - Yeah, no shroud. I also read that a shroud could/should drop the temp a bit too.
I'd still like to hear where others might warm up to. Perhaps someone out there with 350 or better still a 327.
Oh yeah, I removed my overflow tank too, to clean up the engine compartment. Perhaps there's just not enought coolant in the system to keep the temp down.
I guess this brings up another question - how much cooland shoule be in a SBC and do I need a overflow or a reserve tank?
| | | | | Joined: Apr 2007 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2007 Posts: 92 | Found the cooling system capacities. It's 17 quarts for 62-65 SB Chevys. | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | Heavy you have a problem temps to high. Did the truck originally have a 6cyl. radiator may be to small, plugged up? how close is the fan to the radiator? Really needs to be about 1 1/2 inch from it and have a shroud to cool it down. small block is a long way from the radiator. I have a .060 over 261 6cyl in mine and it steady as a rock at 180. new radiator no shroud.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The radiator capacities are the same on the '55-'59s regardless of engine, the only difference would be wheater or not it had a heater and the block capacity. However, the V8 engine will sit back from the rad. I beleive on the later TF trucks, they moved the rad back a bit to compensate for that, but also, V8 trucks used a fan shroud as well. I woudl stongly suggest a shroud, and possibly a fan spacer to get it closer to the rad. You may want to consider adding an overflow bottle, too, so that the system will reclaim any overflow rather than just dumping it out.
Bill Burmeister | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | for every lb of pressure on your cap raises the boiling point of the water 3 degrees in your system. if you are running a 50-50 mix of antifreeze and water it raises the boiling point another 18 degrees eg; 7lb cap raises it 21 degrees F. 212 + 21 + 18 a/f= 251 degrees before boiling 15lb cap = 45degrees F 212 + 45 + 18 a/F + 275 degrees F before boiling if you are running plain water with no pressure sap it will boil at 212 degrees F ron the above figures only work if your cap is working properly and if your cooling system can handle that pressure and is not leaking anywhere losing pressure
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | First thing to check is if your gauge is correct. An inferred thermometer is good for this. A cooking therm. will work. Then try another thermostat. I find about 1 in 5 are defective. Does it go right up that temp. & stay there or does it only get hot on a hard pull or slow traffic or hot weather? They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | Hi all. . . been a while since I've posted. I've been working at work on the truck on the HOG and my marriage (not in that order  ) Anyway - I know someone here will have an answer for me.... I have a SB 327 in my 3100 and my gauges are all new and senders as well. So I'm driving around town puttin her through her paces and I notice that the water temp just keeps climbing. . . 190 - 200 - 210 and then stops around 220. I've also changed the coolant and thermo (180). Is 220 water temp right for this engine? I've also got some tuning to do with the cold idle, choke (or something in this area). It's real choppy in the acceleration till it gets all wormed up (220). Let me know if you need any more info - but the big question here is about the water temp. Thank experts  the questions are what pressure of a cap are you using has the rad been rebuilt or replaced from original what coolant mixture are you using ron | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Like Wrenchbender says, diagnose it first. If it's not boiling out of the radiator, which it should at 220, look at the accuracy of the guage first, Scott | | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | LongBox - Yeah, no shroud. I'd put all of Scotts money on the lack of a shroud. I'm running a 350 horse 350 in mine with a stock radiator and shroud and never run hot. edit - by the way, nice truck.
| | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | A 15 lb. pressure cap will raise the boiling point to 257 degrees with plain water, slightly higher with a 50/50 antifreeze/water mixture (Not 18 degrees!) The only purpose a reservoir tank serves is to give the occasional puke somewhere to go to be recovered once the temperature goes down and a suction develops in the radiator. The puke can hose should always be submerged in the coolant in the reservoir so it can siphon the coolant back into the radiator on cool-down. It sounds like your radiator isn't doing its job; either it's too small, or dirty, or both. A fan shroud will also help to keep the air flowing through the radiator instead of around, or behind it. Position the shroud where the fan fits halfway into the opening for best efficiency- - - -the end of the shroud should cover only half the depth of the fan blades; it should not have the blade fully enclosed, nor stop ahead of the blade. Jerry
| | | | | Joined: Jul 2008 Posts: 413 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 413 | 220 is a bit high for that engine. I have a 327 in my chevelle, it's basicly stock other than it has a factory 350 horse cam in it . Mine usualy runs at 210, or just a tad under. Im also willing to bet your radiator isnt doing its job. | | |
