| | | Forums66 Topics128,024 Posts1,055,393 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 208 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 208 | Ok - I'm gathering parts for the power brake conversion. I have a 58 3200 bone stock 235 3 on the tree - drum/drum.
I have already purchased the wheel cyls & brake hoses.
I want to buy the power master cyl next month (saving my pennies) but there is a huge difference in price on the kits I've seen.
I know you usually get what you pay for, but - how much difference can there be? I've seen kits for less than $200 & more than $500 & all in between.
Do I need a proportioning valve? What is this flow back valve some kits talk about needing?
I will buy a bolt in kit - don't want to fab or weld if I can help it.
Once this is done - I will install seat belts & pretty much be safe to drive with the kids.
any help? | | | | | Joined: Apr 2009 Posts: 431 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 431 | if i'm correctly remembering, the prop valve is for disc/drum combos, and maybe so with the dual master. but i think the dual master may also be a function of safety. pop a leak in one circuit, the other is still operable | | | | | Joined: Mar 2009 Posts: 208 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 208 | Has anyone installed power brakes on their bolt?
What are the advantages vs dis-advantages of one brand over another? | | |
