0 members (), 160 guests, and 5 robots.
Topics128,149
Posts1,056,818
Members48,456
#58172 03/23/2006 3:52 AM
Apprentice
Apprentice
Could somebody out there please tell me the difference between the 54 & 55 1st series 3100? Thanks
#58173 03/23/2006 3:57 AM
A model year? I don't think there's any other difference,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#58174 03/23/2006 4:44 AM
Different side emblems on the hood.
Open driveshaft in 1955-1st.
H55 as the first three characters on the door hinge pillar plate for 1955-1st; H54 for 1954.
Different shades/names for the "white" top on the exterior two-tone deluxe cab.
#58175 03/23/2006 11:03 PM
Riding in the Passing Lane
Like TC says the main difference is the open drive shaft on the 55-1. There is also a different water pump & pulleys. I believe the 55 is 12 volts. Someone correct me if i,m wrong.
1972 Chevy c10 Cheyenne Super
#58176 03/24/2006 3:52 AM
The '55 1st Chevy I have is six volt.
#58177 03/24/2006 12:49 PM
55 1st ser is 6 volt...doc
#58178 03/24/2006 6:30 PM
A significant difference is the open drivetrain. Both have 3.90 differential but if you intend to keep the rear axle and swap gears you can go with 3.38 while the 54 swap is for 3.55. The rear springs are the same overall length but the "center" hole is located differently. The 54 rear spring mounts to an offset rubber insulated "projection" off the axle while the 55.1 bolts directly to the axle. In 54 the grill background color is white but is black on 55.1.
Mike Barnes
1950 GMC 1-ton pickup
#58179 03/24/2006 7:59 PM
Chrome grills were offered for the 55.. 6v trucks...biggest difference is the hotchkiss rear end...no torque tube...and as pointed out the--option now to go to 3:38 gears. The 55.1 (the last of the breed) was factory superior to the 54 from a highway perspective and incorporated the open rear end which virtually all rodders of prior year AD trucks perform on their trucks to make them hiway capable.
Importantly, the 55.1 was only in production for 1/2 year and in my experience is far more difficult to locate.
Buzz'n Half Dozen
#58180 03/25/2006 1:09 AM
50GMC253,
I am very interested in knowing more about 1955-1st grills. It is my understanding that the standard 1955-1st grill is all white (no "inner" and "outer" grill different in color). Is that correct?
When you state "In 54 the grill background color is white but is black on 55.1.", are you referring to the chrome grills for both years?
Tim
#58181 03/25/2006 7:23 PM
I guess we're back to posting the same question in multiple forums again...
As far as the grilles go, my 54 4400 is solid white.
1954 GMC De Luxe COE
#58182 03/26/2006 3:03 AM
TClederman--
My 55.1 chrome grill has no painted background--all chrome. Appears to be original.
Buzz'n Half Dozen
#58183 03/26/2006 4:11 AM
Buzz'n,
Thanks for the information. I just now looked at a 1955-1st sales brochure. It does not have any chrome grills but all the white grills had black "CHEVROLET" letters on the top bar and black inner bars. I had never noticed this.
One of my '54 pick-ups had an all-white grill. A case of a repaint of a slightly damaged grill. I found this out when I starting stripping off the paint.
On your '55-1st chrome grill, are the parking lamp panels and the lower grill pan chromed? They were not chromed in '54. And, in '54, the inner grill bars were bright white. This is in all the '54 sales brochures and I once saw a pristine, original '54 Deluxe Cab (green exterior with green/green interior) with all the deluxe chrome options (and 18,000 miles on it).
THe grills seem to be the major obvious difference between '54 and '55 first.
What is the code on the ID plate on your 3100 truck? I am interested in knowing if they actually changed to the '55 code (H55...) or if they continued to use the '54 code (H54...).
Tim
#58184 03/26/2006 3:21 PM
Tim --
My truck's ID code is H55 and the lower grill panel is chromed as are the parking lamp panels. Importantly, this truck is not a deluxe cab which leads me to believe that the chrome option was available on some non 3104 trucks or could be ordered. As a result of my inspections of the truck and my discussions with the PO I am convinced (as I can be with a 50 year old truck) that the chrome grill is original.
In my search for a first series 55 AD truck, I only found two other trucks both in too poor condition to purchase. One was advertised as a 54 but it was a 55.1 and the door plate showed H55. The second truck was marked the same (H55). Both of those trucks had painted grills but unfortunately the original paint was gone or overpainted in both cases. I believe that the white with black background was the factory paint on non-chrome grills as you state.
I suspect that the Chevrolet on the upper bar of my grill was originally painted black but the paint is gone. I say this as the chrome side badging (55 badges) had a black background and some of the original paint remains.
I agree that the grill was an obvious pointer to the difference between the two model years, The other being the side badging which is plainly different in 55.
I saw your website over at Kookbolt--your truck, the carryall and their restorations are impressive smile .
Buzz'n Half Dozen
#58185 03/26/2006 8:08 PM
Buzz'n,
"this truck is not a deluxe cab which leads me to believe that the chrome option was available on some non 3104 trucks or could be ordered"
In 1954 and I bet in 1955-1st, there was RPO 393 Chrome Equipment, which included chrome grill, chrome front bumper, and chrome hubcaps.
That option was separate from the 5-window RPOs, such as:
RPO 390 De Luxe Equipment (for bigger trucks) did not include the 393 chrome pieces
RP0 430 & 431 De Luxe Cab Equipment (included two-tone interior(four combinations by late '54) and other goodies, but not the 393 chrome pieces
So, your chrome grill could easily have been delivered as you describe.
Tim
#58186 03/27/2006 4:44 PM
Since my 55.1 3100 is was not original I have sniffed around a lot trying to find the truth. I don't know for certain if I've found the truth but I am satisfied with my conclusions based on deductive reasoning and viewing of black and white factory pictures.
I don't think any of the 3600 and larger 55.1 trucks were different from 54 mechanically except for the 261 engine and related parts.
There are conflicting "facts" out there about the grille colors for 3100 between the years. Another thing which I think may produce errors is the true fact that a lot of folks with a 54 model think they have a 55.1 and vice versa. I do know I've viewed a lot of black and white factory pictures and can tell the bottom pan was not chromed on any of them and the background color is very light or white on the 54s and very dark or black on the 55.1s.
The closest thing to fact about the chrome grilles I have found is in a parts book printed in late 1955. The grille on the 1954-55 trucks was not sold as a complete replacement assembly but in pieces. It shows 4 replacement parts available as chrome: The top bar, vertical center nose, and the left and right hand center bars. There is no reference to the parking lamp panels and the lower grille bar being available in chrome.
I know one fellow who said this about the painted 3100 grille:
"I sold an unmolested 55 1st series truck a few years ago. The truck was painted the original green. The outer portion of the grill was green & the inner portion [ behind the double lip] was waldorf white AKA eggshell. Only the 2 wings & the lower baffle got the white inner highlight. The top bar was all green [ with white lettering ] 2 middle wings were green from the double lip forward. Lower baffle was green from the double lip forward. Nose cone was all green [ no white at all on this piece at all ] Park light surrounds were all green."
Did he really have a 55.1 is my question. Was it actually original is the other.
Now I know another guy with an "original" 55.1 chrome grille. It has the black background on the nose and center bars. The bottom pan and parklights are body color.
Eventually I decided there is no such thing as absolute facts. My 55.1 grille now has white header, nose and center bars, with flat black background. Bottom pan, parklight ends and bumper filler panel are body color. I honestly believe this would have been correct from the 55.1 factory. If not so be it. I like it.
Mike Barnes
