| | | Forums66 Topics128,029 Posts1,055,417 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 23 New Guy | | New Guy Joined: May 2009 Posts: 23 | What did I do? I purchased a 1952 3100 in pieces. The engine has a casting number of 3692703 and a serial number JAD766756. The head has a casting number of 3835499. The websites that I checked show that I have a block for a 235 passenger vehicle with powerglide and the head is from a 1950 216. It was together when I bought it but it was not running due to a broken valve seat. The head is machined and the Valves ground (intake measures 1.92"). I purchased a valve grind gasket set from Jim Carter that doesn't fit and baffels them. Anybody know what I have and will it work? It seems to match and the old head gasket seems to have worked. I sent it to them to match but they claim I have a 1954 235. I couldn' t be that lucky. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Inliners site shows it as a 1950-1952 235 http://www.inliners.org/ 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The JA part of the code pegs it as a '51 engine, the "D" part isn't listed in my books, most likely, with the casting number coming up as a 235, it's out of a '51 Powerglide car.
Bill Burmeister | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | You have the same setup as I have. I don't know about your block number but the head was used on 216s and possibly 235s. You must have the short side cover, correct? They made 216s and 235s in 1950 to 52 that had the short side cover but were still low pressure motors. I originally had a head with a Canadian casting number but it had a crack. I now have the same head as you and they are identical. The gasket set you need is for a 1950 to 52 Powerglide. | | | | | Joined: May 2009 Posts: 23 New Guy | | New Guy Joined: May 2009 Posts: 23 | ME211c2 seems to match up to the gasket that I sent them. Thanks for all the info.
| | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | Master Parts Catalog, 1925-1951 effective April 1, 1951
Block casting 3692703, part # 3695755 1950-51 - Pass. w/P.G.
Head casting 3835499, part # 3835545 1950-51 - All w/235 Eng.
Do you have hydraulic lifters.
-Tom
1950 Chevy 3100 w/ 1956 235
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I just found something interesting in the Truck Cumulative Index for service literature for 1951:
"216 engine to use the 235 cylinder block and cylinder head castings"
Maybe this explains some of the mystery. This was the era when they made 216s with the short side cover. The cylinder head was different from the previous version and different again from the 1953 version. | | | | | Joined: May 2009 Posts: 23 New Guy | | New Guy Joined: May 2009 Posts: 23 | I do Have hydraulic lifters. | | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | The MPC is listing all 216's with the large side cover & all 235's with small side cover. Sometimes catalogs are in error, so maybe someone will chime in and verify if the catalog is correct. 0.439 - Cover, Valve Push Rod http://chevy.oldcarmanualproject.com/1929_54chevyparts/00/106.HTM
-Tom
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | It can't be correct for both high side cover and short side cover because the block and head design are different. | | |
