4 members (Peggy M, Gib70, Gray_Ghost, 1 invisible), 252 guests, and 2 robots.
Topics128,089
Posts1,056,117
Members48,434
I have a 37 1.5 ton on the pass side of frame behind cab inside the frame it says "body builder do not drill frame use present hole or " and i cant make the rest out does any body know what this may have said thanks dave
Probably said use U-bolts?
May have said drill web (not top or bottom flange) if absolutely necessary.
My 48 frame had something stenciled in the same place about not welding, wish I had a good picture of it before sandblasting...
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
Heat treated frames still have often stickers on them from the factory stating "DO NOT DRILL OR WELD FLANGES". So I am pretty sure that is what it said or something to that effect even though the oldies were no heat treated material. If may have also said something about drilling in the first two feet back of cab as that is where 90% of frames fail.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
it says"body builder do not drill frame use present holes or ----ers with u-bolt" . thanks for the u bolt tip know only need to know one word please help open to even any guess thanks dave it does look like the last three letters are ers thanks again dave
spacers with u-bolts
1959 Chevy Apache
1948 Chevrolet COE
Trucks are like womens handbags !! you can never have enough of them and they can carry all your worldly possesions
