| | | Forums66 Topics128,077 Posts1,056,014 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 5 New Guy | | New Guy Joined: Oct 2009 Posts: 5 | I have a 37 1.5 ton on the pass side of frame behind cab inside the frame it says "body builder do not drill frame use present hole or " and i cant make the rest out does any body know what this may have said thanks dave | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Probably said use U-bolts? May have said drill web (not top or bottom flange) if absolutely necessary.
My 48 frame had something stenciled in the same place about not welding, wish I had a good picture of it before sandblasting...
Grigg | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Heat treated frames still have often stickers on them from the factory stating "DO NOT DRILL OR WELD FLANGES". So I am pretty sure that is what it said or something to that effect even though the oldies were no heat treated material. If may have also said something about drilling in the first two feet back of cab as that is where 90% of frames fail. | | | | | Joined: Oct 2009 Posts: 5 New Guy | | New Guy Joined: Oct 2009 Posts: 5 | it says"body builder do not drill frame use present holes or ----ers with u-bolt" . thanks for the u bolt tip know only need to know one word please help open to even any guess thanks dave it does look like the last three letters are ers thanks again dave | | | | | Joined: Sep 2007 Posts: 140 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 140 | | | |
