| | | Forums66 Topics128,036 Posts1,055,460 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 40 Apprentice | | Apprentice Joined: Mar 2009 Posts: 40 | I rebuilt this 235 almost three years ago and I finally got in in my 62 c-10 and I have even been driving it around the hood , but I keep forgetting to put a bolt in the harmonic balancer . It does have one right? If so I can't find it and I don't know what size it is? can anyone help this weekend parts replacer ? | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I just use the same kit for a small block V8 (bolt & thick washer), but you will have to drill and tap. Should have been done when rebuild, but I just eyeballed mine and it's been there for 18 plus years. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Supposedly, some later 261s crank shafts came drilled for a harmonic balancer bolt (replacement engines), but most (if not all) were not drilled. This bolt/washer set is readily available at most parts stores and it is the bolt-size for which most people/shops drill/tap the crank shaft. Tim | | | | | Joined: Mar 2009 Posts: 40 Apprentice | | Apprentice Joined: Mar 2009 Posts: 40 | So are you saying they only put on a bolt when the engine has been rebuilt ? were they just pressed on originally , then once removed the bolt is put on just in case ? | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | If You drill and tap the crank it is easyer to install the harmonic balancer ,You don't have to bang it on with a hammer , I did mine 7/16 X 20 thread most HB installer kits come with a 7/16X20 stud some places You can rent them .
Pete | | |
