4 members (MickeyP, Phak1, Steveoreno, Waveski), 77 guests, and 0 robots.
Topics128,188
Posts1,057,332
Members48,469
#579587 10/01/2009 7:53 PM
Apprentice
Apprentice
I rebuilt this 235 almost three years ago and I finally got in in my 62 c-10 and I have even been driving it around the hood , but I keep forgetting to put a bolt in the harmonic balancer . It does have one right? If so I can't find it and I don't know what size it is? can anyone help this weekend parts replacer ?
I just use the same kit for a small block V8 (bolt & thick washer), but you will have to drill and tap. Should have been done when rebuild, but I just eyeballed mine and it's been there for 18 plus years.
1946 1/2-Ton Chevy
Supposedly, some later 261s crank shafts came drilled for a harmonic balancer bolt (replacement engines), but most (if not all) were not drilled.
This bolt/washer set is readily available at most parts stores and it is the bolt-size for which most people/shops drill/tap the crank shaft.
Tim
Apprentice
Apprentice
So are you saying they only put on a bolt when the engine has been rebuilt ? were they just pressed on originally , then once removed the bolt is put on just in case ?
If You drill and tap the crank it is easyer to install the harmonic balancer ,You don't have to bang it on with a hammer , I did mine 7/16 X 20 thread most HB installer kits come with a 7/16X20 stud some places You can rent them .
Pete
