0 members (),
200
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#57945 03/18/2006 11:22 PM | Joined: Sep 2004 Posts: 46 Member | | Member Joined: Sep 2004 Posts: 46 | Installed my new rocker arm today on my '54 235 and noticed that there is a gap about 1/2 to 3/4 inch between pushrod and the rocker arm ajusting screw. The cam is new as well as the lifters (solid).The old rods were 10-9/16" so are the new ones..so whats gotten shorter? lifters, cam lobes, or?? | | |
#57946 03/18/2006 11:34 PM | Joined: Sep 2003 Posts: 324 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 324 | Compare your lifters new to old as far as height. You will probably find your difference there. You will need the correct push rods. | | |
#57947 03/19/2006 12:11 AM | Joined: Sep 2004 Posts: 46 Member | | Member Joined: Sep 2004 Posts: 46 | Thanks 235FF, The machine shop dumped the old lifters, so..I guess the next rod size up would be 11-1/4. | | |
