1 members (Hotrod Lincoln), 49 guests, and 6 robots.
Topics128,021
Posts1,055,355
Members48,420
#579209 09/30/2009 8:42 PM
I have a '65 C-10 I just bought. It has the old 4- speed transmission(granny gear). My question.... I would like to put a three speed std. tranny in it. Is it just a matter of unbolting the old and putting in the other? 230 inline... Thanks
You'll need to have a driveshaft made. The yoke on the granny 4-spd is fixed on the trans, it doesn't slide in like the 3-speed. The driveshaft on the 4spd granny has a slip joint built into it.
-Brad
SOUTHERN FALL GABfest
October 6 ~ Commerce, Georgia
Details here!
Never Pee on an Electric Fence.
The transmissions are different lengths, so different drive shafts. There is an exception, there was a heavy duty 3spd option. I've only seen one and that was in a 60 panel I had 30 years ago.
You will also need to shift it. A 3spd shifter on the floor, or find a donor and pull the column,all the linkage, and drive shaft. That's assuming you have the 4spd column now.
There are other problems depending on what year 3spd.
Larry
I don't own a vehicle that isn't old enough to drink.
LGriffin #579400 10/01/2009 4:25 AM
What Brad and Larry said - bolt it in and you'll need a longer driveshaft. Nothing inside the bellhousing needs to change.
There may have been more than one type granny 4 speed as mine had a conventional slip yoke on the driveshaft and standard spline and seal on the back of the transmission. It's an easy matter to slide under and see which you have.
1960 GMC 1/2-Ton Pickup Truck
Updates in the DITY Gallery
Brad54 #579497 10/01/2009 3:25 PM
Thanks to all for the information. It truly helps. I've got a gazillion more questions and I appreciate the response.
