| | | Forums66 Topics128,268 Posts1,058,378 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 66 | I've noticed a few posts about putting a 194 head onto a 235 or 250 to boost compression, is it possible to do something similar to a 292? I have a stock 292 in my truck right now, and a spare 250 sitting in the barn, could I put the 250 head onto my 292 to boost my compression ratio or is it a waste of time to even think about it? | | | | | Joined: Aug 2008 Posts: 230 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 230 | cant tell you how big the cc's are in the combustion chamber's but i took a 230 head and droped some v-8 valves and put it on my 292 and it run's fine .i used it because that was all i had . | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | The 194/230/250/292 are the same family and the heads will interchange. The 235 is a different animal. I think only the 194 head has smaller combustion chambers. | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | Ghostrider has it right. The only head that will get you a compression increase is the 194. The 194 has a 62 vs 72-78cc combustion chamber. That's before any valve or porting work is done. The 194 head will up your compression by about a point, your mileage may vary. Check inliners.org for head casting numbers.
Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Feb 2004 Posts: 29,947 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,947 | I built a .030" oversize 250 some time ago with 307 V-8 flattop pistons and a .050" mill job on the head. It still runs well on 87 octane, and goes like a scalded cat! Jerry
| | | | | Joined: Feb 2000 Posts: 5,265 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,265 | I think some of the 194's and siamese exhaust ports as well as intakes, so check before you buy. | | | | | Joined: Sep 2009 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 66 | Thanks for the info guys, hopefully I can find a 194 head that will work, that I can actually afford. I will definitely check the casting number on here before I buy anything  Any idea about how much it costs to have the valve/porting work done? | | |
