0 members (), 123 guests, and 8 robots.
Topics128,186
Posts1,057,211
Members48,465
Hi all...I need one...any suggestions...Thank You
C Online: Content
Tim, did Chev not use a piece of flex in the line like GMC used. I have had some Chevs for parts vehicles but I never examined them that close and they are now long gone.
crenwelge,
No rubber flex line. Just two brass fittings and a copper line.
Tim
would aluminum tube be ok? older plumbing suppy/hdwr stores carry both by the foot, and the ftgs. in fact, lowes/depot etc carry it, and the ftgs, but in pre-packaged lengths
My AD uses a steel line.
1951 1 Ton Completed
My '37 had a 1/8" brass line on it. I would think copper or aluminum would be to soft. Be sure to add a loop or two for flex.
Joe
C Online: Content
Hardware store copper is for water or AC. I would recommend going to an auto supply. Either loop it or consider a short piece of flexible tubing like GMC of the same era used.
flex? why for flex? the heat causing expansion/contraction?
right, copper for h2o/ac, those are my fields, but i've never heard of a copper alloy for oil, aside from a no copper use with cooking oil, bec it will react with the oil
C Online: Content
The copper lines or ac are a harder alloy. A line running from the engine will have to flex because an engine moves. In a vehicle these days, it will probably be fine, but when trucks were trucks it was a problem because they were driven a lot of miles. Even into the 60's trucks used soft copper for air as well as oil lines. A softer copper alloy lasted much longer. GMC used about a 6" flex hose between the firewall and the engine to solve the problem. If you put AC tubing in a bender and then soft copper from an automotive shop, you can feel the difference.
