| | | Forums66 Topics128,168 Posts1,057,025 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 10 New Guy | | New Guy Joined: Nov 2006 Posts: 10 | Hi all...I need one...any suggestions...Thank You | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | Tim, did Chev not use a piece of flex in the line like GMC used. I have had some Chevs for parts vehicles but I never examined them that close and they are now long gone. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Apr 2009 Posts: 431 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 431 | would aluminum tube be ok? older plumbing suppy/hdwr stores carry both by the foot, and the ftgs. in fact, lowes/depot etc carry it, and the ftgs, but in pre-packaged lengths | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | | | | | | Joined: Feb 2000 Posts: 5,229 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,229 | My '37 had a 1/8" brass line on it. I would think copper or aluminum would be to soft. Be sure to add a loop or two for flex.
Joe | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | Hardware store copper is for water or AC. I would recommend going to an auto supply. Either loop it or consider a short piece of flexible tubing like GMC of the same era used. | | | | | Joined: Apr 2009 Posts: 431 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 431 | flex? why for flex? the heat causing expansion/contraction?
right, copper for h2o/ac, those are my fields, but i've never heard of a copper alloy for oil, aside from a no copper use with cooking oil, bec it will react with the oil | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | The copper lines or ac are a harder alloy. A line running from the engine will have to flex because an engine moves. In a vehicle these days, it will probably be fine, but when trucks were trucks it was a problem because they were driven a lot of miles. Even into the 60's trucks used soft copper for air as well as oil lines. A softer copper alloy lasted much longer. GMC used about a 6" flex hose between the firewall and the engine to solve the problem. If you put AC tubing in a bender and then soft copper from an automotive shop, you can feel the difference. | | |
