6 members (53again, Cosmo, Hotrod Lincoln, mason86, Gray_Ghost, Jon G), 98 guests, and 1 robot.
Topics128,068
Posts1,055,883
Members48,428
#578174 09/27/2009 2:42 AM
Getting ready to put the brakes together,should I lube or grease the threads on the adjusters?...If so, with what ?.Thanks...dave
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
... a dab of anti-sieze will keep it from sticking.
edit: and a "tat" in the other end will help keep it spinning nice and smooth.
Yes, lube the adjusters. Use either brake slide lube or anti-seize. Personally, I use either the Loc-Tite copper base anti-seize, CRC brake caliper grease, or Permatex synthetic brake lube. All 3 work very well.
Don't forget to lube the pads on the backing plate, the parkjing brake actuator arm pivot, and any other sliding/pivoting surface. Not a bad idea to put a bit of lube on the ends of the shoe where it contacts the wheel cylinders and the anchor pin as well.
Bill Burmeister
Thanks guys...........dave
1949 Chevrolet 3100
