| | | Forums66 Topics128,050 Posts1,055,760 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | Getting ready to put the brakes together,should I lube or grease the threads on the adjusters?...If so, with what ?.Thanks...dave
1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ... a dab of anti-sieze will keep it from sticking.
edit: and a "tat" in the other end will help keep it spinning nice and smooth.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Yes, lube the adjusters. Use either brake slide lube or anti-seize. Personally, I use either the Loc-Tite copper base anti-seize, CRC brake caliper grease, or Permatex synthetic brake lube. All 3 work very well. Don't forget to lube the pads on the backing plate, the parkjing brake actuator arm pivot, and any other sliding/pivoting surface. Not a bad idea to put a bit of lube on the ends of the shoe where it contacts the wheel cylinders and the anchor pin as well.
Bill Burmeister | | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | Thanks guys...........dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
