0 members (),
35
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 38 Apprentice | | Apprentice Joined: Apr 2006 Posts: 38 | I have a 67 C-20 (2WD) that I want to convert to 4x4. I local yard has a frame but they want $500. I was hoping there was a cheaper way. I have all new axles and suspension. Another question is...are the frames even any different? transfer case crossmember? Any help would be appreciated.
Nick | | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | I think there is a thread with this same topic, it was about 2 weeks ago. Not sure if it was the same year as yours though. Do a search on 4x4 conversion. | | | | | Joined: Sep 2009 Posts: 24 New Guy | | New Guy Joined: Sep 2009 Posts: 24 | Your best bet is to find another frame. If the local yard wants $500, you need to find another yard..or buy a complete truck. The frames are different, rear will have leaf springs and the frame rises higher in front of the firewall on a 4wd.
1949 Chevy 3800
| | | | | Joined: Mar 2005 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 92 | Coil sprung frames are different than leaf sprung frames. I know the 63 2wd and 4wd's are way different. I'm sure you'll need the 4wd frame, Scott | | |
