2 members (Bill Hanlon, Nuts&Bolts), 40 guests, and 3 robots.
Topics128,014
Posts1,055,324
Members48,419
#577537 09/24/2009 2:07 PM
Apprentice
Apprentice
I have a 67 C-20 (2WD) that I want to convert to 4x4. I local yard has a frame but they want $500. I was hoping there was a cheaper way. I have all new axles and suspension. Another question is...are the frames even any different? transfer case crossmember? Any help would be appreciated.
Nick
I think there is a thread with this same topic, it was about 2 weeks ago. Not sure if it was the same year as yours though. Do a search on 4x4 conversion.
jomichael #577615 09/24/2009 6:03 PM
Your best bet is to find another frame. If the local yard wants $500, you need to find another yard..or buy a complete truck. The frames are different, rear will have leaf springs and the frame rises higher in front of the firewall on a 4wd.
1949 Chevy 3800
BlueJeep #577618 09/24/2009 6:25 PM
Coil sprung frames are different than leaf sprung frames. I know the 63 2wd and 4wd's are way different. I'm sure you'll need the 4wd frame,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
