| | | Forums66 Topics128,023 Posts1,055,365 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 82 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 82 | Did the search thing, but did not come across anything suitable.
The issue is a 58 235 which is getting a new clutch, etc. The flywheel really needs to be resurfaced, and my question is that it appears that it can drop out of the bottom of the bell housing so that I do not have to remove the engine.
Just want to make sure that my guess is correct, and this can be done this way before I start attempting to remove the flywheel.
Additionally, what is the going rate for flywheel resurfacing these days? I also expect to get a new ring gear installed while I am at it.
I expect there is a few of you that have had this adventure before. Thanks for any tips or information you can give.
Richard 58 3104
| | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | yes it comes out the bottom,been a few years since I did mine thinking $20-25 bucks.sometimes they just flip the ring gear over.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Yes, it will drop out the bottom with the removal of the 6 bolts holding it on. Careful!!! Its heavy,, keep your hands away from directly under it while removing it. And, it will only go back on one way when re-installing. I just had mine resurfaced and balanced,,,65.00. Dont know what they charge for new ring gears. Good Luck, Marty | | | | | Joined: Apr 2005 Posts: 82 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 82 | Thanks, Tommy and Marty. Looks like my weekend is planned out. I appreciate the quick responses.
Richard 58 3104
| | | | | Joined: Jun 2008 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2008 Posts: 47 | Anyone know offhand what the torque values should be when tightening the flywheel bolts?
Thanks! Dan M. | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Flywheel bolts are 50-65 ft. lbs. Marty | | |
