Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (3B, Gdads51, Otto Skorzeny, 1 invisible), 93 guests, and 4 robots.
Topics128,281
Posts1,058,472
Members48,490
Can someone please help me with where it mounts.. Can you if possible send me a pic also.. Again thank you for all [email protected]
If I remember correctly, sitting in the drivers seat looking forward,it will mount on the left side of the radiator, on the rad. support bracket. The water hose will clip to the inner fenders and along the firewall then tee off into/onto the 2 water nozzles. The pump wire wil also travel the same route but go into the firewall to the ww switch. grap a copy of the 60-66 assemlby manual.
http://cgi.ebay.com/ebaymotors/1960...490117QQptZMotorsQ5fManualsQ5fLiterature
1960 GMC 305A V-6 Gallery Page
Remember, the government cannot give --anything to anyone --that they have not first taken away from someone else.
BUY AMERICAN http://www.stillmadeinusa.com/index.html
Thanks I will get one...
I'm not sure where the stock one mounted (mine didn't have washers), but that's where I mounted mine - drivers side next to the radiator. I used the bottle from a 1983 Chevy S10. They're cheap and have grommets in the mounting holes.
[IMG]http://img10.imageshack.us/img10/1047/bottlewc.jpg[/IMG]
1960 GMC 1/2-Ton Pickup Truck
Updates in the DITY Gallery
Thank you very much....
Here is a pic of mine, just to the drivers side of the radiator.
http://memimage.cardomain.com/ride_images/3/3525/4881/33812440007_large.jpg
