| | | Forums66 Topics128,050 Posts1,055,759 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 16 New Guy | | New Guy Joined: Aug 2009 Posts: 16 | Can someone please help me with where it mounts.. Can you if possible send me a pic also.. Again thank you for all [email protected] | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | If I remember correctly, sitting in the drivers seat looking forward,it will mount on the left side of the radiator, on the rad. support bracket. The water hose will clip to the inner fenders and along the firewall then tee off into/onto the 2 water nozzles. The pump wire wil also travel the same route but go into the firewall to the ww switch. grap a copy of the 60-66 assemlby manual. http://cgi.ebay.com/ebaymotors/1960...490117QQptZMotorsQ5fManualsQ5fLiterature
| | | | | Joined: Aug 2009 Posts: 16 New Guy | | New Guy Joined: Aug 2009 Posts: 16 | | | | | | Joined: Dec 2008 Posts: 337 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 337 | I'm not sure where the stock one mounted (mine didn't have washers), but that's where I mounted mine - drivers side next to the radiator. I used the bottle from a 1983 Chevy S10. They're cheap and have grommets in the mounting holes. [IMG]http://img10.imageshack.us/img10/1047/bottlewc.jpg[/IMG] | | | | | Joined: Aug 2009 Posts: 16 New Guy | | New Guy Joined: Aug 2009 Posts: 16 | | | | | | Joined: Feb 2003 Posts: 218 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 218 | | | |
