| | | Forums66 Topics128,009 Posts1,055,295 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 143 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 143 | Simple question (I hope) will a 350 out of a 1989 Chevy fit in a 1970 Chevy? Would a lot of work have to be done to get it changed over? | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | yes it will, use your 70 intake and carb unless you want to computerize it. | | | | | Joined: Apr 2008 Posts: 143 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 143 | Okay cool. I don't have the 1970 intake and carb but I'm sure I'll find some parts that'll work. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Pretty basic swap if you do as Tmater says & use older parts instead of the computer controls. The older intakes will not fit because the bolts in the center are straight up. There are special manifolds made to use a carb on these & some specialty manifolds are both ways. Ive heard of filing the bolt holes in the manifold to accept this but Ive never seen it done. You will have to use a flywheel that is with the late engine or get one to fit. They have a balance weight built in & have a different bolt pattern. Rest is pretty basic. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
