| | | Forums66 Topics128,052 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 61 | today i primed my underfloor in grey on the blank metal. what color would you use for the top coating? is black ok or will i have problems later to find partial damage?
'59 Apache '67 Mustang
| | | | | Joined: May 2007 Posts: 275 Shop Shark | | Shop Shark Joined: May 2007 Posts: 275 | You can paint it any color you want to. I usually paint it with grey epoxy primer and leave it at that.
Some paint it the color of the vehicle and some just paint it black.
Frank Cox Cox Custom Cars
No better smell than that of fresh paint. I've been building and painting cars/trucks for 47 years. Not gonna stop now. http://www.coxcustomcars.com/ | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Apache...I don't know if your going for total authenticity but here's what i did with mine it's POR-15. It's very hard wearing and should be good corrosion protection. Something i'm sure you'll need for those cold German winters.... Do they salt the roads in winter there? 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | I used POR 15, then POR Etch Primer, then followed up with POR Hardnose Light Yellow. It is pretty close to the Corvette Yellow I plan on painting my truck. I used this same process on the underside of each fender, and inner fenders. If you do use the Hardnose, it doesn't spray well, I kept it to where I could brush it on, out of most eye sight. Yeah, if someone sticks their head in my fender they might notice a few brush marks. Good luck. | | | | | Joined: Sep 2007 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 61 | @all the truck will not be a daily driver so i only cruise in the summer. and of course they salt the roads in winter ;-)
i took black and a similar "tough" paint like por15 because i already had the primer on the cab.
there are many inaccessible areas underfloor and when the paint is dry, i will use some special penetrating paint and grease to protect the cavities againt corrosion.
| | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | there are many inaccessible areas underfloor and when the paint is dry, i will use some special penetrating paint and grease to protect the cavities againt corrosion. Many years ago in Detroit I learned this trick. Mix STP with kerosene and using a small flexible tube, inject it into all the areas you can't easily reach. The kerosene will evaporate leaving a thin film of STP. I'm not sure where you would find it, but "rustproofing" places use special equipment for doing this. It involves drilling small holes to access places like door pillars and then closing out the holes with plastic plugs. May not be the way to go if you are a purist but if it prevents rust in places like the "rust belt" of the US it's worth considering. | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Apache.....Here's a product favoured by us 'Brits' for rustproofing the cavities in your cab. Waxoyl Trust me,coming from the west coast of Scotland I'm familiar with rust! I've used it on quite a few cars with good results. It's used in a similar way to Woody's suggestion. Stinks a bit for a few days after application but the smell soon goes away. I'm not sure if you could find a stockist closer to home. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Sep 2007 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 61 | jockbolter50, i know the product. it is much more expensive here. i think wax is suitable to protect again rust but it can not stop it permanently. i will use fluid film e.g. and afterwards wax or grease.
| | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | Czechman, How are you "injecting" it? I'm envisioning you taking the tube, sucking in some fluid about half way, inserting it into the pillar and then blowing? I would like to do this to the pillars in my truck. Could even do that around the edges of the headliner and let it run down the sides? That concoction won't hurt the paint if it drips out the bottom will it?
Good idea! | | |
