| | | Forums66 Topics128,274 Posts1,058,432 Members48,489 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#57611 03/10/2006 4:15 PM | Joined: Oct 2003 Posts: 90 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2003 Posts: 90 | I'm looking for some advise about my 4 spd. When I put the shifter plate on, I couldn't get it to shift into any gear, I got the top plate from another 4spd, could this be the problem. Any help would be appreciated. resto44 | | |
#57612 03/10/2006 4:31 PM | Joined: Sep 2003 Posts: 343 Member | | Member Joined: Sep 2003 Posts: 343 | Resto44, When you put the top cover on you need to make sure the all three shift forks go into the correct slots on the main shaft. There are two positions on the main shaft and there is a reverse lever on the inside edge of the case. Also make sure the shift rods/forks move well on the top cover before you install the cover.
Jim
1954 GMC 1/2-ton Longbed 1971 Pontiac LeMans Sport
#57613 03/10/2006 6:26 PM | Joined: Jan 2004 Posts: 223 'Bolter | | 'Bolter Joined: Jan 2004 Posts: 223 | Resto44, I am in the process of rebuilding my SM420 4 sp in my '50. I went to a local rebuild shop to ask them what it would cost for them to rebuild it. They gave me a price with exchange with the proviso that I must have the matching top plate to the transmission because the shifting forks are set up by the factory to match the transmission. This is probably your problem. Steve O | | |
#57614 03/10/2006 7:11 PM | Joined: Nov 2000 Posts: 1,975 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,975 | I don't know. I read too many times of people successfully swapping the tops. Do you know the shift tower/top from the second trans is good?
Professional Novice
