Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Svcattle, baldeagle), 145 guests, and 1 robot.
Topics128,274
Posts1,058,432
Members48,489
#57611 03/10/2006 4:15 PM
I'm looking for some advise about my 4 spd. When I put the shifter plate on, I couldn't get it to shift into any gear, I got the top plate from another 4spd, could this be the problem. Any help would be appreciated.
resto44
#57612 03/10/2006 4:31 PM
Resto44, When you put the top cover on you need to make sure the all three shift forks go into the correct slots on the main shaft. There are two positions on the main shaft and there is a reverse lever on the inside edge of the case. Also make sure the shift rods/forks move well on the top cover before you install the cover.
Jim
1954 GMC 1/2-ton Longbed
1971 Pontiac LeMans Sport
#57613 03/10/2006 6:26 PM
Resto44, I am in the process of rebuilding my SM420 4 sp in my '50. I went to a local rebuild shop to ask them what it would cost for them to rebuild it. They gave me a price with exchange with the proviso that I must have the matching top plate to the transmission because the shifting forks are set up by the factory to match the transmission. This is probably your problem.
Steve O
1950 Chevy 3100
261, 4 speed
Purchased 1977
1964 Pontiac Lemans Convert
#57614 03/10/2006 7:11 PM
I don't know. I read too many times of people successfully swapping the tops. Do you know the shift tower/top from the second trans is good?
Professional Novice
