| | | Forums66 Topics128,049 Posts1,055,634 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | what cam will fit a 194 block. a friend has a shot cam and is looking for a used one to fit his 194 motor. will a 230 /250 cam fit?
thx
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | The 230/250 cam will work, but that's not to say it would be the right cam. You could have problems.
You will need to get a new set of lifters, or use the same lifter on the same lobe it was riding on.
GOOD LUCK!
Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Feb 2000 Posts: 5,199 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,199 | Send me a note, I have a NOS GM 194 cam I will make you a deal on.
Joe | | | | | Joined: Feb 2004 Posts: 29,765 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,765 | A used cam is sort of like a used condom- - - - - -I don't think I'd trust one! Once a cam/lifter wear pattern gets established, it shouldn't be disturbed. At least put in a new set of lifters and go through the same break-in procedure as a new cam- - -20 minutes at 2,000 RPM before you idle the engine at all. Jerry
