6 members (55shaker, Wickedbass, FAST55, rfs56trk, Hotrod Lincoln, Hanks custodian), 57 guests, and 3 robots.
Topics128,065
Posts1,055,868
Members48,428
#575641 09/19/2009 1:21 AM
what cam will fit a 194 block. a friend has a shot cam and is looking for a used one to fit his 194 motor.
will a 230 /250 cam fit?
thx
Jim & Caroline
The 230/250 cam will work, but that's not to say it would be the right cam. You could have problems.
You will need to get a new set of lifters, or use the same lifter on the same lobe it was riding on.
GOOD LUCK!
Larry
I don't own a vehicle that isn't old enough to drink.
Send me a note, I have a NOS GM 194 cam I will make you a deal on.
Joe
A used cam is sort of like a used condom- - - - - -I don't think I'd trust one! Once a cam/lifter wear pattern gets established, it shouldn't be disturbed. At least put in a new set of lifters and go through the same break-in procedure as a new cam- - -20 minutes at 2,000 RPM before you idle the engine at all.
