5 members (Lugnutz, F100Ranger, 55shaker, Otto Skorzeny, Steelonsteel), 88 guests, and 4 robots.
Topics128,140
Posts1,056,466
Members48,441
#575647 09/19/2009 1:41 AM
Ok, I know this has been asked a million times and I should know the answer myself but I have to ask.
I have a buddy with a little driver 51. He wants a taller rear end. I want the 55 passenger car rear he has in it so this is good. Anyway, I know something like a 67-69 Camaro will bolt in, (with re-drilling the thru bolt hole of course) or I imagine the same vintage Nova.
Any others I could tell him about?
He is going to go hunting for a rear and I want the most chances for him to find one.
The truck does have 5 lug on the front so I am looking for a 5 on 4 3/4 Chevy passenger car pattern with 3.00 or so ratio.
Brian
Brian
1948 Chevy Pickup
Chopped and sectioned
owned since 1974 when I was 15.
Brian ,This comes from the Tech Tips here on Stovebolt. As you'll see it gives a lot of dimensions, but no ratios. Your friend will have to fiqure that part out himself.
http://50chevy.freeservers.com/Suspension_Widths.html#Suspension
Drew
You might check out the 3rd generation Camaro diffs. (5 on 4-3/4 bolt pattern, 62" wheel mounting surface to mounting surface) I'm running an 1988 3.42 from behind a 2.8L V6 with a .72 T5 from an S10. The most common ratios are 3.08 and 3.42 with an occasional 3.73.
Being a coil spring diff you have to scrub off all the unnecessary brackets and weld on new spring perches (1-3/4 trailer perches from Tractor supply). The axle tubes are 2-5/8 so it's a good idea to use a piece of 1/8 x 1" flat stock as a shim if you're going to use 3" U-bolts. The stock emergency brake cables can be tied into the AD emergency brakes so try to save them. The Camaro rear sway bar is a perfect fit (39" eye to eye) when mounted on top of the diff with the control links forward of the diff. The IROC-z Australian made Borg Warner diffs are posi/discs, primarily in 3.08 but the axle seals are not available from GM dealers. Never did find any aftermarket seals. Posi/disc is tempting but be forewarned.
Although these diffs require a bit more prep to get them set up for the AD truck, I've found they are for the most part, in pretty good shape with lower mileage, readily available and normally $100.-$150.00.
With a 3-1/2 to 4" backspaced rim they will center in the AD wheelwell. Check out the install pics in my webshots album. Hope this helps.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
Have him call Moser and they'll make it any way he wants,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
