| | | Forums66 Topics128,030 Posts1,055,430 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 57 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 57 | '61 C20: Bought OEM light switch to replace bad one that didn't work at all. The parking lights work fine, but the front ones go off when you pull switch out for headlights. Is that normal? | | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | Yup, it's perfectly normal. | | | | | Joined: Nov 2008 Posts: 57 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 57 | | | | | | Joined: Sep 2009 Posts: 4 New Guy | | New Guy Joined: Sep 2009 Posts: 4 | Isn't there a trick to wiring those so they stay on when the headlights are on? | | | | | Joined: Dec 2008 Posts: 337 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 337 | | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | | | | | | Joined: Aug 2007 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 67 | Both work I did the second one FriedGreentmater had. That way they r always on I also did one off the number 5 tail light balde so I can have just parking lights wiht no headlights.
1947 1Ton stepside 1962 K20 Fleetside 1962 C40 12' flatbed 1963 C10 Stepside 1963 C20 Fleetside 1965 C10 Stepside (Daily Driver) 1973 C20 Stepside fire truck 1973 C50 Utility truck Houston Power & Light
| | | | | Joined: Sep 2009 Posts: 4 New Guy | | New Guy Joined: Sep 2009 Posts: 4 | Excellent. Thanks Markeb and all for the links. | | | | | Joined: Jan 2007 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 81 | I had a problem show up on my 1960 1/2t. When I first started driving it,all my lights worked normally as expected.It passed state inspection. Some time later,I noticed my tail lights worked as parking lamps, but went out when the headlights were turned on. Being smart like I am, I looked at the wiring diagram and concluded that the only way this could happen had to be the result of a contact failure inside the light switch. No big problem, I ordered and replaced the light switch. Guess what.. I still had the same problem. I could see no way to fix the problem other than to add a 12v relay by tapping into wiring under the dash. I wired the relay to energize from the light switch feed to the dimmer switch, applying power to the single wire feeding both tail lights. I still have no idea what happened to cause the problem. meansam | | | | | Joined: Aug 2009 Posts: 15 New Guy | | New Guy Joined: Aug 2009 Posts: 15 | meansam, I have led's tail/brake lights on my 66, the brake lights would work as well as the turn signals on both sides, until I turned on the headlights. I would lose one (Not necessarily the same one) brake lights when applied. The turn signals would still work properly. Turned out it was a ground problem, following the circuit back thru the front lamps. I added ground straps everywhere, engine to body,(I forgot to replace) engine to frame, frame to bed. Seemed to take care of my problem | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | I agree with taclem based on first hand experience....
My grandfather had a '72 C20 that my dad had given to him. (Lived in Ohio back then and the road salt ate the body off this truck.)
When the turn signal was on all the lights (tail lamps and side marker lights) would flash, not real bright, but they would flash.
I took a wire, stripped the insulations off, and touched the bumper with the one end and the tailight housing with the other end. Viola! that fixed it.
We took each of the tail lamp assemblies off and hard wired a pigtail from the housing to the trucks frame, aka made our own ground straps.
It fixed the problem.
Since then whenever I have an electrical glitch / gremlin the first thing I do is run a temporary ground wire to see if it fixes the problem.
John | | |
