2 members (3B, baldeagle), 105 guests, and 7 robots.
Topics128,014
Posts1,055,328
Members48,419
#57503 03/07/2006 6:53 AM
Does any one know which pto would fit a New Process 5 speed (I think it is a 540 but not sure)from a 1958 Chevy 2 ton. Or which pto fits a spicer 5831A auxiliary transmission?
#57504 03/07/2006 8:40 PM
It matters a great deal what the models of your transmission is. For example there are big differences between a NP54o and a NP542. Next you must know your requirements, i.e., what do you wish to operate with a PTO? Rotation needed? Which side of the tranny? Remote ot direct mount pump? Shaft size? Control type? Speed required?
See what I mean? It is simply not enough to say "I think it is a 540" and ask for a PTO. There are a lot of things to consider. If you'll give me the answers to these things I'll be able to help you or anyone at a power drive dealer will be able to also.
If you cannot find a model number on your transmission then remove the PTO cover plate where you want to put it and count the number of teeth on the PTO drive gear, whether it's in front of or behind the ctr line, LH or RH pitch or spur gear. Then we start our detective work.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
#57505 03/12/2006 4:28 AM
Dave,
Thank you for the reply. The transmission has the following casting #s C-91171 and the NP for New Process. There is no other identification on the case. There are 15 teeth on the transmission grear for the PTO. The gear is straight cut. I will use the PTO for a dump bed on my 1.5 ton '54 Chevy. Thank you for your help Roger
#57506 03/12/2006 2:43 PM
Need to know if opening is on LH or RH side and is the gear at the front or rear of opening. Also is this a 4 speed or 5 speed?
Are you sure it's a New Process?
Current catalogs don't have all the older transmissions listed so this a problem but I'll keep looking if you'll supply the rest of the needed info.
Spicer brand tranny isn't listed at all in current Chelsea catalog. No 5831 in Muncie catalog. Using an auxillary transmission probably isn't the best choice anyway as the main would have to be engaged in order for it to run PTO. Question: why would a 1.5 ton have an auxillary transmission? Most old Chev. had 4 speed SM420 GM trannys.
Dave
#57507 03/13/2006 6:59 AM
Dave,
I have a stock 1.5 ton 4400 '54 chevy. It has a '54 235 with a sm420. In order to get a lettle more speed I plan to install a 261 with a 5831A spicer auxiliary trans (27% over drive). I also have a new process 5 speed which gives me a better gear range. The sm420 has to large a gap between 3rd and 4th gear. I currently have a PTO on the sm420 which runs the lift bed (this was a grain truck). With the new process 5 speed I would need a PTO on the driver side.
I understand that to run a PTO off the auxiliary trans I would need to have the transmission in direct drive 1:1 or 5th gear. Since I didn't know what might be available in PTOs I thought I would check both the spicer and the new process.
I am open to suggestions.
Thank you for your efforts,
Roger Pell
#57508 03/14/2006 12:20 AM
Roger: I have researched this as far as I can with the resources I have available and have determined that the NP540 is an expensive and poor choice for your application. On the LH side a single gear PTO will require a vertical offset adaptor gear, 093. spacer and stud kit. The adaptor may cost more than a PTO. Also you must consider what rotattion you will need. Single gear units rotate crnk but if you need opposite crnk rotation then you must go to a double gear PTO that cost a lot more and you still require the adaptor, spacer and stud kit. All of them run fairly slow, SG is only 25% od engine speed. Too slow really for a hydraulic pump which likes about 60-70% of engine speed. Also this outfit requires 10 inches of free space to the frame flange so it's a large and heavy unit.
Unfortunately I am unable to find out anything on the Spicer 5831 unit. It's too old so you'll need to go to a good PTO drive dealer like Fleet in CA and hope they have some old books. Got rid of all my old stuff a long time ago. Sorry I am unable to be of more assisitance to you.
Good Luck.
Dave
#57509 03/14/2006 6:15 AM
Thank you Dave for all the effort. Maybe I should rethink this and just run the sm420 which already has a working PTO. Some times simple is better.
Roger
