3 members (MRMEROTH11, delwrench, 1 invisible), 69 guests, and 4 robots.
Topics128,190
Posts1,057,223
Members48,465
Folks - I'm swapping my 51 AD 3 Spd for a Saginaw 4 Spd. While I have the tranny out I want to try to confirm the viability of the clutch without acutally removing it. I have the bell housing cover off, I'm laying on my back looking up with a flashlight, what next? I wasn't having problems with the clutch before the swap, and I think this truck is in pretty good shape. The tranny gears have minimal wear patters, no tip wear, but, I would like to check out the clutch before I just replace something with 50% plus life left in it, not to mention the work involved. Thanks in advance for any helpful advice.
1951 Chevrolet 3100 AD Pickup
It's kind of an "experience" thing to be able to eyeball a clutch disc for wear. The best way would be to remove it and see how much material is left, before hitting the rivots, compared to a new one. While it's out you can inspect the rest for hot spots and cracks too,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Riding in the Passing Lane
The condition of the lineing is like 48 said. It,s kinda from experience. You might look at a new one & get an idea. Don,t try to compare measurments as the disc is comepressed when ingauged. If it worked smooth & looks like it has enough lining it will be ok. You can check the throwout brg. It should turn smooth with out any noise.
1972 Chevy c10 Cheyenne Super
I
I Offline
If it was my truck, I wouldnt take any chances that there was something wrong, while i had it opened up. The first two things to go out, are the throw out bearing and the clutch disc. I would also check out the bushing in the end of the crank, as long as your already there. If the tranny is out, it dont take but a short time to check out this other stuff.
Jeff
1947 Chevy 6400 2-ton
1953 3/4-ton
It was fun while it lasted
Thanks for your thoughts on this .... I agree, as long as I've come this far I might as well go all the way and remove the clutch for inspection. Regards,
