| | | Forums66 Topics128,181 Posts1,057,152 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#57492 03/07/2006 4:35 AM | Joined: Jun 2000 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2000 Posts: 50 | Folks - I'm swapping my 51 AD 3 Spd for a Saginaw 4 Spd. While I have the tranny out I want to try to confirm the viability of the clutch without acutally removing it. I have the bell housing cover off, I'm laying on my back looking up with a flashlight, what next? I wasn't having problems with the clutch before the swap, and I think this truck is in pretty good shape. The tranny gears have minimal wear patters, no tip wear, but, I would like to check out the clutch before I just replace something with 50% plus life left in it, not to mention the work involved. Thanks in advance for any helpful advice.
1951 Chevrolet 3100 AD Pickup
#57493 03/07/2006 4:44 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | It's kind of an "experience" thing to be able to eyeball a clutch disc for wear. The best way would be to remove it and see how much material is left, before hitting the rivots, compared to a new one. While it's out you can inspect the rest for hot spots and cracks too, Scott | | |
#57494 03/07/2006 11:12 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The condition of the lineing is like 48 said. It,s kinda from experience. You might look at a new one & get an idea. Don,t try to compare measurments as the disc is comepressed when ingauged. If it worked smooth & looks like it has enough lining it will be ok. You can check the throwout brg. It should turn smooth with out any noise. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#57495 03/08/2006 12:26 AM | Joined: Nov 2005 Posts: 355 Member | | Member Joined: Nov 2005 Posts: 355 | If it was my truck, I wouldnt take any chances that there was something wrong, while i had it opened up. The first two things to go out, are the throw out bearing and the clutch disc. I would also check out the bushing in the end of the crank, as long as your already there. If the tranny is out, it dont take but a short time to check out this other stuff. | | |
#57496 03/08/2006 2:43 AM | Joined: Jun 2000 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2000 Posts: 50 | Thanks for your thoughts on this .... I agree, as long as I've come this far I might as well go all the way and remove the clutch for inspection. Regards,
