2 members (baldeagle, 78buckshot), 20 guests, and 3 robots.
Topics128,037
Posts1,055,467
Members48,424
#573071 09/10/2009 4:22 PM
Hello all, I need help with my gas tank, the filler tube is pushed in and the rubber gasket is coming out, since my seat dose not fold over I thought I would ask how to fix this before I tear into it, can I just vise grip the filler tube and pull it back? how do I deal with the gasket, it looks to be a big P.I.T.A. ---pain in the ###
Thank you
You're going to need to gain access behind the seat, either by moving it forward or pulling it. The filler neck is about 4 inches long, and attaches to the tank via a heavy wall rubber hose, and 2 clamps - one near the tank and the other near the top. The upper one can be difficult to reach, but if it's the original you it should have a 1/4" hex so you can use a wrench or small ratchet.
On your truck it's likely one of the clamps is loose, or missing - or the hose is so old it's bulging so much it's not holding the filler neck in place. If this is the case you will need a new hose. Truth is, if it's original it needs to be replaced no matter what since 40+ year old gas hoses deteriorate.
It may take some effort, but once the clamps are loose the filler neck just pulls out. It's much easier to replace the grommet with the neck out, although some have installed the grommet with the neck in place, using string like when installing a windshield.
1960 GMC 1/2-Ton Pickup Truck
Updates in the DITY Gallery
Markeb #573119 09/10/2009 7:26 PM
Markeb, covered the basics with good info. Here's a thread that goes into more on whether the seat needs to be removed or not.
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=571911#Post571911
Larry
I don't own a vehicle that isn't old enough to drink.
LGriffin #573278 09/11/2009 5:29 AM
Ok, thank you both for the information, very helpful
When you tackle this be very patient. I had to do this on my 61 and it was a pain in the butt. Take your time and try to have a friend with small hands come over smile I could barely fit my paws up into the space to mess with the top screw.
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton
My Machine
