| | | Forums66 Topics128,036 Posts1,055,461 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 175 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 175 | Hello all, I need help with my gas tank, the filler tube is pushed in and the rubber gasket is coming out, since my seat dose not fold over I thought I would ask how to fix this before I tear into it, can I just vise grip the filler tube and pull it back? how do I deal with the gasket, it looks to be a big P.I.T.A. ---pain in the ###
Thank you | | | | | Joined: Dec 2008 Posts: 337 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 337 | You're going to need to gain access behind the seat, either by moving it forward or pulling it. The filler neck is about 4 inches long, and attaches to the tank via a heavy wall rubber hose, and 2 clamps - one near the tank and the other near the top. The upper one can be difficult to reach, but if it's the original you it should have a 1/4" hex so you can use a wrench or small ratchet.
On your truck it's likely one of the clamps is loose, or missing - or the hose is so old it's bulging so much it's not holding the filler neck in place. If this is the case you will need a new hose. Truth is, if it's original it needs to be replaced no matter what since 40+ year old gas hoses deteriorate.
It may take some effort, but once the clamps are loose the filler neck just pulls out. It's much easier to replace the grommet with the neck out, although some have installed the grommet with the neck in place, using string like when installing a windshield. | | | | | Joined: Jan 2009 Posts: 175 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 175 | Ok, thank you both for the information, very helpful | | | | | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | When you tackle this be very patient. I had to do this on my 61 and it was a pain in the butt. Take your time and try to have a friend with small hands come over  I could barely fit my paws up into the space to mess with the top screw.
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton My Machine | | |
