| | | Forums66 Topics128,014 Posts1,055,333 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2000 Posts: 112 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 112 | Does any body know the I.D. of a Ad truck steer column and the O.D. of the steering shaft that goes through the tube column..I was wondering if they make a bearing to slip inside of the column over the shaft to secure it so it would not wobble... The fellow I'm asking the question for wants to keep his original steering column...but want to change his front suspension...
1946 chevy 1/2 ton panel 1937 ford coupe | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | There has been a thread here on the bolt about that very subject. You should be able to find it by doing a search here on the ~Bolt - I think the pilot-bearing from a semi truck is very close in dimensions.
| | | | | Joined: Dec 2002 Posts: 55 Member | | Member Joined: Dec 2002 Posts: 55 | On Chuckthetruck's great web site, I believe he has some pics of how he shortened his original steering shaft by cutting it and fitting another top shaft bearing at the bottom of the shaft. I'm not sure of the link, but I believe he had to ream out the bottom of the tube or something...maybe he will see this and explain it better. | | | | | Joined: Dec 2000 Posts: 112 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 112 | Thank you fellow bolters...chuckthetruck if you got your ears on..hope you will reply..I read your material posted (nice site)...how to keep original column..I understood using the mask bearing column on the lower end..inside the column tube to support the shaft from wabbling But I'm not quite sure what were the reasons for the two flat washer and the bronze thrust bushing. And also did you ever figure out a way to secure the column it self...Your reply would be apprecialted...jdhoward
1946 chevy 1/2 ton panel 1937 ford coupe | | | | | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | The thrust washer arrangement was just to take the end load from the spring "upstairs". It may have worked without it, but it didn't hurt to add it. I searched to find a bearing that would drop in without machining and was unsucessful, but the upper mast bearing is working fine. I never did get around to adding more column support. It is still just the clamp at the dash and the flange at the floor. One of these days, but it is working fine. I did have to add a ground lead from the rack to the frame so the horn would work.
3600 miles now - just finished a 560 mile round-trip fishing expedition with no problems. | | | | | Joined: Dec 2002 Posts: 55 Member | | Member Joined: Dec 2002 Posts: 55 | Hey Chuck - do you tow a boat with your AD? I am building up my truck now from boxes of parts I got it in, and I have a small 16' BassTracker aluminum boat with a 50 HP and single axle trailer. I was wondering how I could rig up a reese hitch. Seems the bumper may be in the way, don't know for sure since I'm not that far yet, but if I need to hook to the frame, now is the time to do it, before I put the bed on.. any experience with this? thanks!!! | | | | | Joined: Jan 2000 Posts: 206 Member | | Member Joined: Jan 2000 Posts: 206 | The correct bearing is #6203. This is a common light duty ball bearing and can be found at any Toro lawn mower dealer. Cost - about $7.50. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | My truck came to me with a "Valley RV" hitch that has a tongue weight rating of 500 lbs and a tow weight of 5000, if I remember right. It is a thick 1/2", at least, flat chromed piece of metal that starts at a frame crossmember and goes between the bumper and the tailgate. I haven't used it but it looks to be quite strong and well installed.
#5749 03/26/2003 12:42 PM | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | Gobsow, no boat, I'm a shoreangler fishing for "America's Toughest Sportfish For 100,000,000 Years" Visit www.bowfinanglers.com (shameless plug) Sixpack, my memory could be going but I believe the shaft was .75 diameter and the 6203 shows a .6693 ID. I suppose the shaft could be turned. http://www.yida-bearings.com/bearing/6200%20series%20bearings.htm | | | | | Joined: Jan 2000 Posts: 206 Member | | Member Joined: Jan 2000 Posts: 206 | Chuck you are right on the shaft dia. I don't rememeber turning down the shaft but 6203 is the # on the bearing in my truck. | | |
