0 members (), 118 guests, and 3 robots.
Topics128,186
Posts1,057,320
Members48,469
#574186 09/14/2009 10:24 PM
Apprentice
Apprentice
I picked up an automatic choke carb at a swap meet . I rebuilt it and put it on my 55, 235. It is working well except for the choke, does anyone know where the heater tube is supposed to run to ? I am not above reinventing something but I do want to keep this carb. THanks!!
rick tool #574190 09/14/2009 10:43 PM
The auto choke carb came out on the cars, trucks had a manual choke. The car used a formed sheet metal plate located on the top of the exhaust manifold with a hole in it for the tube. Locating one is another story.
Fred
rfs56trk #574207 09/14/2009 11:35 PM
Riding in the Passing Lane
There is a universal choke stove available. You can make one by wrapping some copper tube around a runner on the exhaust manifold. Connect the tube to the fitting by the choke coil. The other end of the tube can be connected by a rubber tube to the tube on the neck of the carb, or it can point down & draw air from under the manifold.
1972 Chevy c10 Cheyenne Super
rfs56trk #574209 09/14/2009 11:35 PM
Apprentice
Apprentice
does the heated air come from exhaust air or air heated from outside the exhaust manifold ? I am thinking I can just make a little metal box with a screen that mounts to the exhaust manifold , then runs to the choke intake. Wadauya think?
rick tool #574210 09/14/2009 11:38 PM
Thated work. The air needs to come from outside the manifold & be heated by the heat from the manifold.
The carburetor on 235 truck engines on Hydra-Matic-equipped trucks came with an automatic choke, using the tube and manifold stove as was used on car 235 engines.
In this photo, you can see the tube and almost see the stove.
As Wrenchbender Ret. confirmed, the tube goes into a hole in the stove and is warmed by the heat coming from the manifold - from the warmed air and by contact with the warmed/hot stove.
Tim
tclederman #574242 09/15/2009 12:52 AM
Apprentice
Apprentice
thanks guys, I now have the confidence to go make something that should work, however ugly it may be! do you have any idea what they used to keep from sucking junk into the carb, It must have some kind of screen or filter ?
rick tool #574246 09/15/2009 12:58 AM
Nothing gets "sucked" into the carb. As I recall the tube transfers heat to a spring inside the choke unit. The spring expands when heated, turning the choke "flapper" (valve) inside the carburetor.
Tim
rick, I'm 90% sure I have the factory tin part you need, it's yours if you pay for postage. You can send me a private message and we can work out the detail.
Jim
1946 1/2-Ton Chevy
