| | | Forums66 Topics128,188 Posts1,057,332 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 40 Apprentice | | Apprentice Joined: Mar 2009 Posts: 40 | I picked up an automatic choke carb at a swap meet . I rebuilt it and put it on my 55, 235. It is working well except for the choke, does anyone know where the heater tube is supposed to run to ? I am not above reinventing something but I do want to keep this carb. THanks!! | | | | | Joined: Apr 2005 Posts: 2,102 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,102 | The auto choke carb came out on the cars, trucks had a manual choke. The car used a formed sheet metal plate located on the top of the exhaust manifold with a hole in it for the tube. Locating one is another story. Fred
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | There is a universal choke stove available. You can make one by wrapping some copper tube around a runner on the exhaust manifold. Connect the tube to the fitting by the choke coil. The other end of the tube can be connected by a rubber tube to the tube on the neck of the carb, or it can point down & draw air from under the manifold. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2009 Posts: 40 Apprentice | | Apprentice Joined: Mar 2009 Posts: 40 | does the heated air come from exhaust air or air heated from outside the exhaust manifold ? I am thinking I can just make a little metal box with a screen that mounts to the exhaust manifold , then runs to the choke intake. Wadauya think? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Thated work. The air needs to come from outside the manifold & be heated by the heat from the manifold. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | The carburetor on 235 truck engines on Hydra-Matic-equipped trucks came with an automatic choke, using the tube and manifold stove as was used on car 235 engines. In this photo, you can see the tube and almost see the stove. As Wrenchbender Ret. confirmed, the tube goes into a hole in the stove and is warmed by the heat coming from the manifold - from the warmed air and by contact with the warmed/hot stove. Tim | | | | | Joined: Mar 2009 Posts: 40 Apprentice | | Apprentice Joined: Mar 2009 Posts: 40 | thanks guys, I now have the confidence to go make something that should work, however ugly it may be! do you have any idea what they used to keep from sucking junk into the carb, It must have some kind of screen or filter ? | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Nothing gets "sucked" into the carb. As I recall the tube transfers heat to a spring inside the choke unit. The spring expands when heated, turning the choke "flapper" (valve) inside the carburetor.
Tim | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | rick, I'm 90% sure I have the factory tin part you need, it's yours if you pay for postage. You can send me a private message and we can work out the detail. Jim | | |
