1 members (delky),
127
Mod | | | Forums66 Topics128,193 Posts1,057,258 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 15 New Guy | | New Guy Joined: Jul 2009 Posts: 15 | During the unusual ease of tracking down the title for my truck, I learned that the cab is the 'Custom' cab with large window off of a long bed fleetside. Now it sits on a shortbed frame that will have a stepside box. I'm just curious if this would have been an actual production unit... I don't know alot of this type of history.
Thanks | | | | | Joined: Oct 2008 Posts: 321 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 321 | If I am understanding your questions correctly.... Could a Shortbox, Stepside truck have had a Custom cab w/ large back window in 1966.... Yes, it probably was produced. This was a time when you could easily go to a dealer and get exactly what you wanted (within a certain list, of course). Pretty much anything was possible.
1963 Chevy C20 Longbed Stepside 1978 Chevy K30 Custom Deluxe
| | | | | Joined: Aug 2006 Posts: 237 Shop Shark | | Shop Shark Joined: Aug 2006 Posts: 237 | I agree with Mike.. I have a friend with the same one but it was a 65 that his dad got new.
Jesus is Lord! Only through the blood of Jesus are you washed clean of your sins. Come see us... Dad's Chevy Our VideoGod bless you! Michael..
| | | | | Joined: Feb 2002 Posts: 2,896 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,896 | Custom Cabs were a trim package... they had the flags on the doors, extra trim... usually had some other chrome items here and there as well. I think the same plastic knobs inside had the plastic chrome on them...
If you check out the gallery here at the bolt you will see some examples of it.
-W
| | | | | Joined: Aug 2007 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 67 | I agree a custom cab could be had on all the trucks even the larger trucks. So what makes you think the cab is from a longbed? The vin? If The vin tells you it came off a long wb then thats were it came from. When these trucks were put togther many moons ago, They started as a build sheet. So if it statarted down the line as a long wb it got a vin num of a long wb and vise versa. So if your vin number in the cab says its a long wb and its on a short wb frame I would say some one other than the factor changed your cab. Maybe I read to much into your question, but I hope this helps. But who realy cares what the cab went to as long as your happy with what you got. Bet theres not a lot of people that would even notice. Good luck with it!
1947 1Ton stepside 1962 K20 Fleetside 1962 C40 12' flatbed 1963 C10 Stepside 1963 C20 Fleetside 1965 C10 Stepside (Daily Driver) 1973 C20 Stepside fire truck 1973 C50 Utility truck Houston Power & Light
