5 members (latroca52, Woogeroo, Mike Burns, Rusted Nut, TS3600), 68 guests, and 3 robots.
Topics128,188
Posts1,057,334
Members48,469
#547670 06/18/2009 2:31 AM
'61 C20: Bought OEM light switch to replace bad one that didn't work at all. The parking lights work fine, but the front ones go off when you pull switch out for headlights. Is that normal?
Nomad02 #547674 06/18/2009 2:39 AM
k10 Offline
Yup, it's perfectly normal.
k10 #547755 06/18/2009 12:09 PM
Thanks!
Nomad02 #573386 09/11/2009 6:39 PM
I
I Offline
Isn't there a trick to wiring those so they stay on when the headlights are on?
1960 GMC 1/2-Ton Pickup Truck
Updates in the DITY Gallery
Markeb #573446 09/12/2009 12:25 AM
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Both work I did the second one FriedGreentmater had. That way they r always on I also did one off the number 5 tail light balde so I can have just parking lights wiht no headlights.
1947 1Ton stepside
1962 K20 Fleetside
1962 C40 12' flatbed
1963 C10 Stepside
1963 C20 Fleetside
1965 C10 Stepside (Daily Driver)
1973 C20 Stepside fire truck
1973 C50 Utility truck Houston Power & Light
I
I Offline
Excellent. Thanks Markeb and all for the links.
I had a problem show up on my 1960 1/2t. When I first started driving it,all my lights worked normally as expected.It passed state inspection. Some time later,I noticed my tail lights worked as parking lamps, but went out when the headlights were turned on.
Being smart like I am, I looked at the wiring diagram and concluded that the only way this could happen had to be the result of a contact failure inside the light switch. No big problem, I ordered and replaced the light switch. Guess what.. I still had the same problem.
I could see no way to fix the problem other than to add a 12v relay by tapping into wiring under the dash. I wired the relay to energize from the light switch feed to the dimmer switch, applying power to the single wire feeding both tail lights. I still have no idea what happened to cause the problem.
meansam
meansam #575172 09/17/2009 4:32 PM
meansam,
I have led's tail/brake lights on my 66, the brake lights would work as well as the turn signals on both sides, until I turned on the headlights. I would lose one (Not necessarily the same one) brake lights when applied. The turn signals would still work properly. Turned out it was a ground problem, following the circuit back thru the front lamps. I added ground straps everywhere, engine to body,(I forgot to replace) engine to frame, frame to bed. Seemed to take care of my problem
meansam #575212 09/17/2009 6:45 PM
I agree with taclem based on first hand experience....
My grandfather had a '72 C20 that my dad had given to him. (Lived in Ohio back then and the road salt ate the body off this truck.)
When the turn signal was on all the lights (tail lamps and side marker lights) would flash, not real bright, but they would flash.
I took a wire, stripped the insulations off, and touched the bumper with the one end and the tailight housing with the other end. Viola! that fixed it.
We took each of the tail lamp assemblies off and hard wired a pigtail from the housing to the trucks frame, aka made our own ground straps.
It fixed the problem.
Since then whenever I have an electrical glitch / gremlin the first thing I do is run a temporary ground wire to see if it fixes the problem.
