3 members (Donf, rfs56trk, BC59), 106 guests, and 3 robots.
Topics128,086
Posts1,056,101
Members48,434
#571911 09/06/2009 6:07 PM
Help! Every time I fill the tank up I get a major gas smell in the cab. You really can't drive it because the gas smell is so bad. I replaced the rubber grommet on the filler neck and also checked the gasket on the sending unit, which was fine. It looks like there is some gas residue on the area where the neck goes into the tank and there is a strong gas smell there also. Any suggestions?? Is it time to replace the tank?
1964 Chevy C10 Stepside
More pix on Photobucket
The primary cause of the gas smell is normally the filler neck hose connecting the filler neck to the tank. The neck sticking out of the cab through the grommet is a separate piece, not part of the tank. The connector hose is about 5" long and has two clamps, one on the bottom at the tank and one at the top at the neck. In some cases one of the clamps is missing, but normally after decades of age the hose itself is deteriorated to the point it's split letting fumes into the cab. Gas residue on the tank would tend to confirm this. Unless you have a hole in the tank somewhere, replacing the hose should cure your problem.
At least it should cure it back to as good as original. Gas stink in the cab was always a problem with these trucks even when new, on a full tank and especially in the summer. It's because the cap is a vented style, so to allow air into the tank the cap also allows fumes to escape right next to the window.
1960 GMC 1/2-Ton Pickup Truck
Updates in the DITY Gallery
Markeb #571919 09/06/2009 6:36 PM
Can this be done without taking the tank out?
its alot easier to cut the tank loose to do this loosen the hold down straps and the gas line and slide to passenger side.Then its much easier to get the clamp at the tank-hose connection.I had this problem for years and changing that hose cleared it up Takes a bit of time but its worth not gettin gassed timbuk
65 Chev shorty
65 Chev longbox
65 Chev crewcab
65 Chev bus!
Photobucket pictures
timbuk #571934 09/06/2009 7:32 PM
timbuk, is right. I had to do it on one of my trucks and cured the problem. The clamps are not easy to, and having the tank does help. I was able to get my replacement hose from NAPA.
Larry
I don't own a vehicle that isn't old enough to drink.
Thanks for the help!! Looks like I have some work to do!
keep it half full till you get it replaced.
Redryder pix
My Hotrod
joker #572015 09/07/2009 12:37 AM
It may be easier with the tank out, but you might want to check out the following link before you pull it:
http://67-72chevytrucks.com/vboard/showthread.php?t=360086
It can be done with the tank in as indicated by a few people.
Markeb #572351 09/08/2009 2:53 AM
k10 Offline
I had a tank split at the seam on the pass. side. Just replacing the hose would never have cured it. If you haven't already restored your truck, I suggest pulling the tank and checking it out front to back, inside and out. Maybe repaint it while it's out, and then you have piece of mind that the job is done. You may want to add some sound deadener while it's out. And clean all those leaves and mouse droppings!
k10 #572592 09/08/2009 11:18 PM
Look in side as you fill it if it runs down thats your hose. Rubber does not last for ever. 40 years aint bad though. I have always left the tank in there and had no big problem, but iam 5' 9" 125 soking wet so i can get in tight palces. And I have "Worked my fingers to the bone. What do you get? Boney Fingers" Good luck whatever way you do it.
1947 1Ton stepside
1962 K20 Fleetside
1962 C40 12' flatbed
1963 C10 Stepside
1963 C20 Fleetside
1965 C10 Stepside (Daily Driver)
1973 C20 Stepside fire truck
1973 C50 Utility truck Houston Power & Light
i once had the welded rear cab mount bolt under the tank break lose on a rather rusty 71 chevy pickup i had many years ago...the bolt actually poked a hole in my tank!
k10 #573281 09/11/2009 5:32 AM
I thought the dead leaves and mouse droppings WAS the sound deadener lol
