1 members (Hotrod Lincoln), 49 guests, and 6 robots.
Topics128,021
Posts1,055,355
Members48,420
#572730 09/09/2009 12:04 PM
I took the truckout last night for a last ride before I prep for paint and spray on some color.
I was looking around for my sanding block and foud a old sanding sponge. I bought it many years ago to sand drywall and it was a disaster. I don't know why I kept it all these years but the prep gods smiled on me as I tried it on my truck last night.
It was alost enjoyable to use on the primer and the painted areas of the truck. It leaves a nice smooth finish, no wrinkling of the paper to cause scratches or grooves. It is easy to hold onto and control. And it seems to last for a very long time. I sanded for a few hours last night and the sponge still seems to have the same abrasion level.
One side is a little more abrasive than the other. I am going out tonight to see if I can get more. I have seen these at Home Depot (where I bought this one 20 years ago).
I will post type and manufacturer if anyone is interested.
RB53
1953 3/4-Ton Chevy
More pix
If it can be built ... It can be fixed.
RB53
RB53,
I've used these on a fair amount of autobody work with good results and you can usually catch them on sale. Everything goes on sale at HF eventually. Have fun and good luck
Dan
Do you know what grit is on the sponge??
If not, you may be in for a lot of resanding.
Typically these sponges are a 180 or 220 grit, which is much too coarse to apply your finish coat over without showing a lot of sand scratches.
For a urethane finish, the coarsest I would use is 400 wet or dry paper.
Nice that you are enjoying it. Be aware though, that because these pads are soft and spongy, they will conform to the surface irregularities in the paint/body and will not help to flatten out imperfections as a standard sanding block would. Have fun.
Wally,
That's very true. My painting skills leave a lot to be desired. I am using these to cut the rough finish on my primer. I will switch to 400 with real sanding block once I get a little closer to smooth.
1953 3/4-Ton Chevy
More pix
RB53
